Toolpath being cut
Toolpath being cut
Dick_axford_HBCSV
Toolpath being cut
Dick_axford_HBCSV
Good morning,
I'm having an issue where I'm trying to ballnose a surface and no matter the toolpath, Morph, Geodisc or flow it always is being cut off in the same place, but the drive surface or rails being selected are either continuous or not broken.
I can't share the CAD so I'm looking for any ideas what causes this issue?
Many thanks
Chris_Townsley
Are you using the "contact point boundary" check box?
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
