Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Tool stops when I don't think it should?
1 REPLY 1
eerier_bleach0f
148 Views, 1 Reply
"Stop tool on collision" is checked off but this isn't:
So the setting is greyed out:
Tool stops on every collision:
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
1 REPLY 1
When "Stop on collision" is checked off tool will stop on collision.
To change it you can check off "Stock" then uncheck "Stop on collision" and then uncheck "Stock" if that is what you need.
After that it should look like this:
If my answer helped you, please click Accept Solution. Thanks!
Dominik Żarczyński
Customer Technical Success
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
