Fusion Manufacture
Tool path parameter expressions - possible bug??
11 REPLIES 11
Message 1 of 12
changedsoul
344 Views, 11 Replies
I think I may have found a bug.
I was editing my tool path parameter expressions and noticed this entry_angle doesnt report the value its supposed to.
I havent tested with other tool paths, just this Face tool path for lathe.
The lead in value on the Linking tab, I wish to utilize the lead in angle in a calculation on Radii tab.
As you can see in the picture below, the value of the lead in angle should be 80, but when entered into the expression editor, its being reported as 3.14961.
Is there some conversion going on?
Thanks.
Edit: Looking further, it looks like its converting the angle value into metric mm.
Doesnt make sense to me for an angle, but maybe for programming ease. It may also be an overlooked bug.
Edit Again....
Trying to make some math calculations and angles seem very confusing to me.
For example, a simple
Math.cos(45) returns "0.020682 in)
This doesn't seem to be DEG or RAD.
Can someone help me out with what this is being calculated as?
Thanks.
11 REPLIES 11
Message 2 of 12
RoccoHilton
in reply to: changedsoul
the outer radius of the crop and the inner radius of the crop must be strictly on the surfaces. Maybe this will help you
Message 3 of 12
changedsoul
in reply to: RoccoHilton
Sorry, No this doesn't help me at all.
Im trying to understand the expressions, not where the inner and outer radius are supposed to be.
Message 4 of 12
jeff.pek
That certainly does look wrong. Are you able to record a short video showing the steps you're taking?
  Jeff
Message 5 of 12
changedsoul
in reply to: jeff.pek
I can try and remember how to do that screen record thing.
Basically i just selected a lathe facing tool path, went to tool path tab for selecting radii boundaries and tried to enter a formula using the lead in values from another tab on the same tool path.
Ill post back a video if i can figure it out. Might be a few hours until i get to work and try it.
Message 6 of 12
jeff.pek
Looks like you're trying to use `entry_angle`, which is an angular value, to the offset, which is a linear value. That would need some sort of conversion to be applied to convert the angle value into an appropriate linear value.
Jeff
Message 7 of 12
jeff.pek
Do you want something like "Math.cos(entry_angle)"?
  Jeff
Message 8 of 12
changedsoul
I was actually trying to limit unwanted small movements by calculating a start point based on lead in angle and length.
For example if lead in angle was 45 and lead in length was .015
I wanted to do
Math.cos(45)*.015
But using expression variables instead.
But the math returns results i cant understand.
I would expect
Math.cos(45)*.015 = .0106
But its some value i cant see how it gets.
Message 9 of 12
jeff.pek
Angle values in expressions are interpreted to be in radians, not degrees. So that's why Math.cos(45) doesn't give you the answer you expect.
Message 10 of 12
changedsoul
If that were true I wouldn't be so confused.
cos(45) should be .707 yet i get 0.02068
Ok, maybe the angle needs to be in radians first.
45*(PI/180) = .7854
cos(.7854) should be .707 but I get 0.0278.
My brain is not clicking on what is going on here.
Message 11 of 12
jeff.pek
It's possible that what you're seeing is unit conversion (mm -> in) happening when the value is presented, rather than a change in the actual value. Since cos(angle) is a ratio, applying the unit conversion probably doesn't make sense.
Jeff
Message 12 of 12
changedsoul
It give a strange answer whether or not you convert it though, thats my point.
Unless I am missing something, I dont see how you can get the correct answer for Math.cos(45).....
Ok, well while I was typing this, I am working on another lathe project and it is working on this project the way I expect:
"Math.cos(entry_angle*PI/180)*(entry_distance)" = .0106 (As I was expecting the other project to display)
Only difference is the X axis on the one that doesn't work is pointing towards the Back plane, and the one that works is pointing towards the Front plane.
Is this intended behavior?
Edit: Ok, now I am loosing my mind. I opened the project that was not working and now it is working. I dont know what I was doing. Seems I had an ID10T error.
