Tool orientation goes wrong way
On [T1] Scallop2(3) I have my Z axis tiltet the way I want, but when I tilt the X axis, it for some reason moves the Y axis to the side instead of moving X axis up? (This is for a 5 axis machine with rotating table A and C)
See screenshot and .f3d file
Replies (11)
I am not working with 5 axis but I think I know enough to be dangerous and I noticed you are not picking correct features on model to define tool orientation.
If I pick edge for X axis it aligns itself with model, also in setup you left Z axis undefined,.... "Nothing", could be source of other problems later.
in WCS I left it on "nothing" because my drawing is set in a Z position that matches the table on my machine, ive been doing this for months and never had an issue.
I think you've missed my point so I will try to be more specific:
Right click on the scallop process called "[T1] Scallop2(3)" and choose "Edit" and then go to "Geometry".
I have chosen my Z and I have choose my X.
If you look on the Z surface I have chosen, the Z orients correctly just how I want it to tilt my table.
If you look on the X surface I have chosen, the X orients incorrectly because instead of moving the X arrow away from the surface I picked, it moves the Y axis to the side.
Imagine the CNC table in front of you. I want the Z axis pointing up as I have chosen (spindle axis up and down), I want the Y axis pointing forward (my table A axis have tilted 90degrees towards me with the part). I want the X axis up a bit on the surface I have chosen (C axis rotates a bit clockwise).
mattdlr89
I've just had a look at this but I'm not quite sure what you are trying to do. Normally I would select a face for the Z axis and an edge for the X.
I think it is move Y because it is not possible to position the WCS how you are saying? Do you want the X axis to be normal to the surface in Scallop2(3) (see screenshot)?
In my defense, I did mention I know just enough about 5 axis to be dangerous so I'll pass for now :beaming_face_with_smiling_eyes:
daniel_lyall
Are you sure you want the X-axis at that angle?
The Y-axis part yes that's wrong.
I think it is an imposable selection you can use turn and tilt if you have it to set the X at that angle but Z moves then it is completely wrong and Y is correct.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
You managed to do it how I want it to be, but I don't have Manufacture extension to be able to do the same.
Yes exactly! I want my X axis to be pointing same direction as that line you have drawn.
daniel_lyall
I have the extension I tried it without it it will not work, if you have a lot of this sort of thing it is worth it to get the extension I only program this sort of thing and it pays off.
Daniel Lyall
The Big Boss
Mach3 User
Tell that to my boss haha.
I will consider this topic solved because it seems like the solution is to have the extension.
I fixed the issue by using one of our longer Ø25mm ball nose mills so I dont have to tilt the table to avoid crash into holder.
mattdlr89
@Anonymous
It should be possible without the extension. Either by drawing a sketch or being selecting in a different way.
When you select two faces for X and Z you will get a conflict. Ideally you need to select a face then an edge.
I got the following by selecting the face for the X-axis (circled in red) and then for the Z axis I selected that edge as highlighted by Fusion. Is this what you are after? This doesn't require the extension.
Sorry for late response, been busy with work.
Yes! You did it! Thank you very much brother :thumbs_up:
