Tool number above 99 need help
daniel_lyall
daniel_lyall
can fusion use tools over 99 tools I am helping someone who has tools in the 100 + range if we post tool 99 it's ok if we post tool 100 fail city
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
HughesTooling
What post are you using? I just tested the Mach post and it should work up to 256, I tried tool 125 and it worked fine.
Here's the code in mach3.
    if (tool.number > 256) {
      warning(localize("Tool number exceeds maximum value."));
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Looking in the Fanuc post it's set to 99. Look in onSection for the code above and change to whatever the highest tool number you need.
Mark
Mark Hughes
daniel_lyall
@HughesTooling I am use my Y 4th axis post I changed the number from 99 to 999 still fail with tool 101 tryed 299 fail, 256 fail. that's why I ask it should work but fails.
I am going to try with the 3 axis mach3 post it's fine this way.
I am going to do a compare with the 3 axis Mach post and the 4th axis version, see if I can find what's wrong
Thanks Mark
Daniel Lyall
The Big Boss
Mach3 User
daniel_lyall
this is the error log
Information: Configuration: Mach3Mill with A-axis
Information: Vendor: HSMWorks ApS
Information: Posting intermediate data to 'C:\Users\Daniel\Desktop\4th test.tap'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Friday, September 30, 2016 10:26:17 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41078
Configuration path: C:\Users\Daniel\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts\mach3mill Y axis.cps
Include paths: C:\Users\Daniel\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts
Configuration modification date: Friday, September 30, 2016 10:25:02 AM
Output path: C:\Users\Daniel\Desktop\4th test.tap
Checksum of intermediate NC data: 1fd51770719048ad19fba8707cfef0e5
Checksum of configuration: eb70df5496598484ae29373914ce8375
Vendor url: http://www.hsmworks.com
Legal: Copyright (C) 2008-2012 HSMWorks ApS
Generated by: Fusion 360 CAM 2.0.2377
Error: Length offset out of range.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Friday, September 30, 2016 10:26:17 AM
Post processing failed.
Daniel Lyall
The Big Boss
Mach3 User
daniel_lyall
@HughesTooling thank you mark but how silly I found the problem the post did need changed for the tool amount number.
Here is the problem I had to change the length offset and diameter offset to 0 for it to work with the 4th axis post the 3 axis post it did not need changed. so that is what I need to find in the 4th axis post but got it going for now.
Daniel Lyall
The Big Boss
Mach3 User
daniel_lyall
the solution to this was change the tool amount and the tool length amount from 99 to 256, the updated post's are here.
http://forums.autodesk.com/t5/computer-aided-machining-cam/mach3-4th-axis-s-files/m-p/6596091
Daniel Lyall
The Big Boss
Mach3 User
