Fusion Manufacture
Tool List Header Comments - Multiple Offsets Same Tool Number?
12 REPLIES 12
Message 1 of 13
jonathanBUCVS
498 Views, 12 Replies
Currently, if I have T0101 and T0111 both used in the same posted code, the header will overwrite with the last tool so something like:
(T0101 - CNMG432)
(T0111 - CNMG432)
(T0202 - VNMG 331)
would just be:
(T0111 - CNMG432)
(T0202 - VNMG 331)
I am trying to think of a way to adjust the post so that it allows "duplicate" tool numbers when the offset is different. Any thoughts? I can post the post code section if needed, but its the stock one.
Labels (1)
12 REPLIES 12
Message 2 of 13
VicKosta
in reply to: jonathanBUCVS
No need to edit post, just use post processor tab in tool definition.
Message 3 of 13
jonathanBUCVS
in reply to: VicKosta
I understand how to change the offset for the tool. When the entire program posts, the top of the program is a header that contains the tool list as comments. This is the part that is overwritten if there are tools with the same T number but different offsets.
Message 4 of 13
VicKosta
Ah I see, I overlooked the real issue, so I tested small file with T0404 and T0414, results in only T0404 in program hedder but T0414 is in second operation as expected, I tested 4 different posts, same result.
Good enough for me but if you wanna show both, then yes, post will need to be edited.
Message 5 of 13
Hi @jonathanBUCVS
I think it has to be fixed in the getToolTable() function.. i will create a ticket for this.
for time being you can use this modification in the post to get
add this supporting function
// Add form here
function isToolChange(pTool, cTool) {
  if ((pTool.number == cTool.number) && (cTool.diameter != 0 ? (pTool.diameter == cTool.diameter) : true) &&
    (pTool.compensationOffset == cTool.compensationOffset) &&
    (pTool.lengthOffset == cTool.lengthOffset) &&
    (cTool.isTurningTool() ? (pTool.noseRadius == cTool.noseRadius) : true) &&
    (cTool.description == pTool.description)) {
    return false;
  } else {
    return true;
// to here
function onComment(message) {
  writeComment(message);
and change the entire code block form if (getProperty("writeTools"))   to the following codes
 // Replace this codes form
  if (getProperty("writeTools")) {
    var zRanges = {};
    if (is3D()) {
      var numberOfSections = getNumberOfSections();
      for (var i = 0; i < numberOfSections; ++i) {
        var section = getSection(i);
        var zRange = section.getGlobalZRange();
        var tool = section.getTool();
        if (zRanges[tool.number]) {
          zRanges[tool.number].expandToRange(zRange);
        } else {
          zRanges[tool.number] = zRange;
    var previousTool;
      var tool = getSection(i).getTool();
      if (i == 0) {
        previousTool = tool;
      if ((i == 0) || isToolChange(previousTool, tool)) {
        var compensationOffset = tool.isTurningTool() ? tool.compensationOffset : tool.lengthOffset;
        var comment = "T" + toolFormat.format(tool.number * 100 + compensationOffset % 100) + " " +
        (tool.diameter != 0 ? "D=" + spatialFormat.format(tool.diameter) + " " : "") +
        (tool.isTurningTool() ? localize("NR") + "=" + spatialFormat.format(tool.noseRadius) : localize("CR") + "=" + spatialFormat.format(tool.cornerRadius)) +
        (tool.taperAngle > 0 && (tool.taperAngle < Math.PI) ? " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg") : "") +
        (zRanges[tool.number] ? " - " + localize("ZMIN") + "=" + spatialFormat.format(zRanges[tool.number].getMinimum()) : "") +
          " - " + localize(getToolTypeName(tool.type));
        writeComment(comment);
  // <<<<<<<to here
  // absolute coordinates and feed per min
  writeBlock(conditional(getProperty("type") != "A", gAbsIncModal.format(90)), formatFeedMode(FEED_PER_MINUTE), gPlaneModal.format(18));
save the post and test
Boopathi Sivakumar
Senior Technology Consultant
Message 6 of 13
@boopathi.sivakumar
I have copied and pasted the isToolChange function above the "onComment" function, and overwritten the writeTools function. Unfortunately the tool list is not displaying at all.
The value is Yes for parameter "Write tool list" on the Post Process window. I tried a few different part files and a few versions of the post.
Message 7 of 13
Could you attach the modified post here.. You might need to zip the file before attaching here
Boopathi Sivakumar
Message 8 of 13
@boopathi.sivakumar  files attached.
added provided code at lines 958-968 and 830-863
Message 9 of 13
@jonathanBUCVS  Ahh.. its with property definition
need to change this line
  // dump tool information
with this
  if (properties.writeTools) {
Hope this time it should work fine
Boopathi Sivakumar
Message 10 of 13
@boopathi.sivakumar That did work, Thank you.
Let me know if you can think of a simple solution for the following two things:
1. Can we revert to the tools being in numerical order? (instead of in order of use) Im ok with either the tool number or the offset number used to index the list, ie T0101, T0111, T0202, T0222, or T0101, T0202, T0111, T0222
2. If a tool is called twice, it is duplicated in the list (see T1313, where it does a deburring pass after the threading tool)
Here is an example I just posted:
(T0101 NR=0.0156 - ZMIN=0. - GENERAL TURNING)
(T1313 NR=0.0156 - ZMIN=-0.6656 - GENERAL TURNING)
(T0505 NR=0. - ZMIN=0.2069 - THREAD TURNING)
(T0303 D=0.5 CR=0. - ZMIN=-0.248 - FLAT END MILL)
(T0606 D=0.1015 CR=0. TAPER=118DEG - ZMIN=-0.4519 - DRILL)
(T0707 D=0.125 CR=0. TAPER=90DEG - ZMIN=-0.29 - SPOT DRILL)
(T0808 D=0.112 CR=0. - ZMIN=-0.4114 - RIGHT HAND TAP)
(T0909 D=0.1875 CR=0. - ZMIN=-0.334 - FLAT END MILL)
(T1111 NR=0.0156 - ZMIN=-0.25 - BORING TURNING)
(T1212 NR=0.008 - ZMIN=-0.7557 - GROOVE TURNING)
((This is the sub spindle tooling))
(T0232 NR=0.0156 - ZMIN=0. - GENERAL TURNING)
(T0737 D=0.25 CR=0. - ZMIN=-0.29 - FLAT END MILL)
(T1646 D=0.5 CR=0. TAPER=45DEG - ZMIN=-0.202 - CHAMFER MILL)
(T0434 D=0.395 CR=0. - ZMIN=-0.226 - RIGHT HAND TAP)
Message 11 of 13
@jonathanBUCVS Change the tool Comment logic like the below
    var toolList = []; // add this line
    var previousTool;
      if (i == 0) {
        toolList.push(comment);  // Change this line
//add codes form here
  toolList.sort();
  for (var i = 0; i < toolList.length; ++i) {
    if (i == 0 || toolList[i] != [toolList[i-1]]){
      writeComment(toolList[i]);
// to here
  if (false) {
    // check for duplicate tool number
 Check and let me know the feedback
Boopathi Sivakumar
Message 12 of 13
@boopathi.sivakumar   Yes, this works great, thank you! I tested it on a few files and it is exactly what I was looking for.
I am going to try to apply some of this new knowledge to the Excel tool sheet post, as that one also used the getToolTable() function, which I guess doesnt allow duplicate tool numbers with different offsets.
Message 13 of 13
I've edited my NLX Post with this and it works great but i'd love to be able to add the Tool Description to the beginning of the post as well?  Ideally i'd love to see it spit out something like this:
(T0101 -- ISCAR PCLNR16-4JHP, CNMG432 INSERT)
(NR=0.0312 - ZMIN=1.05 - GENERAL TURNING)
(T0102 -- ISCAR SVJCR16-3-JHP, VCGT333 INSERT)
NR=0.0469 - ZMIN=1.05 - GENERAL TURNING)
(T0303 -- ISCAR MAHPR 25.4, 3MM INSERT)
(NR=0.012 - ZMIN=3.2135 - GROOVE TURNING)
These tool lists at the top of the program need to give the operator as much useful information as possible.
Jason
PRL Motorsports
