Announcements
Tool Library Items Not Included
abmachine
abmachine
We are using several tools that aren't included in the tool Library in Fusion. Will the Tool Library be expanding any time soon? Examples attached.
https://www.sandvik.coromant.com/en-us/products/pages/productdetails.aspx?c=881-d1500l20-03
http://www.cuttingtooltech.com/ecat/products/csinks/8nc-010.html
seth.madore
Both of those tools are supported types when you create your own tools. For the drill, set the angle to 180 degrees. For the countersink, define the flat tip diameter.
Are you asking about pre-built tools? I don't think that's in the pipeline, given how easy it is to create your own tool and save it to a local or cloud folder..
Seth Madore
Ketherton21
if you are having trouble creating tools, you can copy an existing example tool, and change whatever you need to change. I basically just "reverse engineered" existing example tools in order to educate myself the proper way to do it.
turning tools are where it gets a little tricky.
Ketherton21
heres a start. double check everything i just rushed through it to try and give you a headstart.drill.pngdrill2.png
