HI All,
I am having a frustrating problem with tool libraries in fusion360 electronics--> manufacturing.
This may be a repeat of :
https://forums.autodesk.com/t5/fusion-360-manufacture/cloud-tool-library-gone/m-p/9504708
But these is not a clear solution posted there.
When working with a circuit board in manufacturing mode I can goto MANAGE --> TOOL LIBRARIES and see all my cloud tools. ( I can also see the file at myhub online).
When I try to set up a DRILL operation I select DRILL --> select tool --> manager opens, but I get empty libraries with filing cabinet icon on all folders accept fusion default. So I cannot select any tools.
This is the case on a new design AND an old design that I have previously drilled with this computer/library/setup. When I open the old files (with a previous drill pattern) --> goto tool select -- I cannot see any tools.
When I try to set up a 2d contour operation --> select tool --> manager opens, tools are all present. Same for old and new.
Why can I not select a tool for drilling -- but I can select tools for milling ?
Fusion does not indicate any errors in my setup that might prevent me from creating a drilling op. I have drills that match the design size.
I tried downloading from cloud and uploading to local -- but that just comes up empty too.
I really hope there is a fix for this. All suggestions welcome.
steve
