Fusion Manufacture
tool inspection/change
2 REPLIES 2
emre_sahin9PU3F
94 Views, 2 Replies
I want a rough operation program in Fusion 360. The mold part is too large. The cutting tool will wear out. I want to check the tips of the cutting tool. For example, after going down the Z axis by 10mm, the cutting tool goes up, puts M01, or works for 20 minutes, then G91 G28 goes to Z0 position, then I change the tips of the cutting tool, and the program continues where it left off. Mastercam has this feature. Nx has this feature. How can I do it in Fusion 360?
I put a link on how to do it in Nx, you can check it out.
https://www.youtube.com/watch?v=SFEZbPSP_5o
2 REPLIES 2
Currently, the only option that's readily handy is to have multiple toolpaths with the same tool, covering the same area, but at different Z depths:
Z0 to Z-10.
Z-10. to Z-20.
Z-20. to Z-30.
etc
etc
We recognize this isn't ideal and have heard as much from our users. I'm not intimately aware of any current project that's meant to address this bottleneck, but I do know the developers are always keen on improving the product.
Seth Madore
Thank you for your reply. I have worked in different software companies before. Fusion 360 is a great program. It also has its shortcomings. I would like to help with ideas on what can be done to improve the program and what features can be improved.
