- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Tool exceeds the boundary limit, “Tool Center on Boundary” mode, in situations when boundary segments face each other and the “Additional Offset” exceeds the (distance between the opposing segments) / 2 value.
It seems that the “Tool Center on Boundary” mode of the limiting mechanism offsets the boundary by the tool radius value and then implements the “Tool Inside Boundary” algorithm instead of using the true tool center value. It is obvious from the tool paths in the attached project which I generated using both limiting modes and respective boundary offset values.
Please tell me if I'm missing something, I am totally new to Fusion, maybe there is an option setting or workaround that I am not aware of. Thank you in advance.
P.S. I zipped the *.f3d, it doesn't let me upload otherwise for some reason.
