Fusion Manufacture
Tool definition error?
2 REPLIES 2
gtprototype
102 Views, 2 Replies
I have encountered a problem with a tool from the Harvey Tool Library.  Everything looks fine in my tool library however, when I use the tool in a tool path it looks like this:
When trying to machine an undercut with it, it behaves like it looks and the mysterious disc gets in the way.  Is the tool definition wrong?
 I've attached a file so you can see the tool definition.
Dale Speakes
prototype technology
2 REPLIES 2
seth.madore
in reply to: gtprototype
This is a long standing issue when adding "Shaft" definitions to your Slot Mill. That said, it's actually a visual error and not impacting your toolpath. Your toolpath is failing for other reasons I've not yet determined.
As a test, I made another tool with no "Shaft" definitions and that too is failing. However, both tools work quite well with Steep and Shallow (set to "Steep" with "Machine Undercuts" turned on.
Seth Madore
gtprototype
in reply to: seth.madore
@seth.madore
Thank you for taking a look at this.  Yes, the anomaly with the tool does have an effect on the toolpath.  I've attached a file and here are a few pictures of the toolpaths for comparison.
Dale Speakes
