Fusion Manufacture
Tool configuration DCLN-R holder / HAAS ST-10Y Lathe
6 REPLIES 6
174 Views, 6 Replies
Im trying to set up a tool for a HAAS ST-10Y lathe, but I have some doubts about it, since Im new to machining Im not sure if the configured tool its kind of an interpretation of the tool in real life and thats why it isnt very accurate, I saw pictures of the DCLN-R holder on the internet and it doesnt look like the one I configured here in Fusion 360, Im afraid that the protuding part can get in the way during a facing operation.
Another thing is, the tool head of this machine is at the rear end (as shown in the picture) and as far as I know the late chuck rotates counterclockwise (as I set the tool), (I havent worked with lathes before dont know if I could change the rotation),  but when viewing the preview the position of the tool does not match.
I hope you can solve these doubts, I am a novice in this field
Labels (3)
6 REPLIES 6
seth.madore
in reply to: 17171140
No, that certainly doesn't look correct, would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
in reply to: seth.madore
Here you go
seth.madore
Ah, that's a bug that we have logged. The image shows that it's based on centerline of the tool, but the actual measurement refers to overall width:
You also had the alignment set wrong. You want it to look like this:
Seth Madore
Thank you!
I just have a doubt, why is the spindle rotation set clockwise (I had set it counterclockwise because I had seen demonstration videos where I saw it rotate counterclockwise), does it depend on which way the machine will rotate or is it activated to set the machine that way?. Im confused
seth.madore
If it's a right-handed holder being used on the main spindle, you're going to want to have it set to CW direction
Seth Madore
Ooh I see, Thanks a lot, your answers have been very helpful!
