Fusion Manufacture
Tonight I Started Getting Warning "Simulation is not using information from the machine or post processor"
3 REPLIES 3
simspacetn
103 Views, 3 Replies
I started getting this warning tonight and I'm not sure why ...
     Simulation may be inaccurate
     Simulation is not using information from the machine or post processor.
     Ensure the setup has a simulation-ready machine and use Simulate with Machine.
I've been using the machine I created plus the related posts for simulation for the past year without issue. My post
capabilities are set to CAPABILITY_MILLING | CAPABILITY_MACHINE_SIMULATION;
Here's what has changed the past few days ...
  • I created a Team Hub on Friday so I can have access to configurations.
  • I exported my tools and other assets from my single storage and imported them to my Team Hub.
  • Tonight I upgraded my Fusion 360 Insider to the latest version.
Any idea if any of these changes may be causing this issue?
Thanks!
3 REPLIES 3
a.laasW8M6T
in reply to: simspacetn
This warning is From the Insider version of fusion(which shouldn't really be discussed on the Public forum - there is an Insider forum for that)
It's just warning the when using Standard simulation that the results may not be accurate, If you use Machine simulation then you will get results based on the machine Kinematics and posted code.
seth.madore
in reply to: a.laasW8M6T
Exactly this. Folks need to be mindful of the NDA that they signed and confine their posts to the correct forums.
Seth Madore
simspacetn
in reply to: seth.madore
Oh shoot ... I forgot about the Insider forum. My bad! While I was not sharing any feature info, I will be more careful regarding that.
Also I was not sure if this may have something to do with creating a Team Hub since I never saw this warning before setting that up.
Thanks guys!
