Fusion Manufacture
Through Tool Coolant
5 REPLIES 5
patrizio.costa
175 Views, 5 Replies
i use a standard Fanuc post (with kinematic definition and some other little customization) on our Yasda 5 axis milling machine.
When i use through Tool Coolant, the machine requires a M116 before the coolant activation, a kind of "function authorization".
Any idea on how to get this?
Thank you!!!
5 REPLIES 5
Hi @patrizio.costa
In the coolant definition object in setting you can change this to get what you have wanted
    coolants: [
      {id:COOLANT_FLOOD, on:8},
      {id:COOLANT_MIST},
      {id:COOLANT_THROUGH_TOOL, on:88, off:89},
      {id:COOLANT_AIR},
      {id:COOLANT_AIR_THROUGH_TOOL},
      {id:COOLANT_SUCTION},
      {id:COOLANT_FLOOD_MIST},
      {id:COOLANT_FLOOD_THROUGH_TOOL, on:[8, 88], off:[9, 89]},
      {id:COOLANT_OFF, off:9}
On the COOLANT_THROUGH_TOOL you can change like this
    coolants: [
      {id:COOLANT_MIST},
      {id:COOLANT_THROUGH_TOOL, on:[116, 88], off:89},
      {id:COOLANT_AIR},
If you want to add any codes while turning off you can add it in the off.
Boopathi Sivakumar
Senior Technology Consultant
thank you for your quick answer.
This is not what i need. In fact, i've already changed this line
in
{id:COOLANT_THROUGH_TOOL, on:50, off:9},
The M116 code must be added in a separate line just before the tool change. I did'nt write it in the question (sorry 🙂)
Thank you
try adding a
writeBlock(mFormat.format(116));
to whever you need, probably right before the Coolant Enable command
Please click "Accept Solution" if what I wrote solved your issue!
This is correct. I wanted to add the M116 just with through tool coolant.
But in fact, i could add it before every tool..
yes so try what I said...
