Threadmilling? Is it working?
steveripplingerjr
steveripplingerjr
Is threadmilling working in Fusion 360 Ultimate?
Will we see some tools added for single point threading and Standard threadmills?
I have a project coming up quickly that will need this function to work properly.
I need to make a fixture with 6-32 threaded holes to shorten some small screws.
Replies (9)
anthony.graves
A threadmilling strategy is part of Fusion 360 and Fusion 360 Ultimate (it is 2D strategy), but we do not currently support thread tools (or Form Tools) inside Fusion. We currently have an open ticket to add this support to our tool library, but I do not have an ETA for you on when the functionality will be added.
Anthony Graves
Product Manager, CAM
steveripplingerjr
Ok, Thanks for the answer.
Hopefully sooner rather than later. : )
jeff.walters
YOu can use a flat mill to do your thread milling. the only thing that wont look correct is the simulation. you will still get the correct code output.
Jeff Walters
Senior Support Engineer, CAM
steveripplingerjr
Ok! I was playing around with it with a regular thread tool and it seemed to give good paths. I have never threadmilled before so it should be a fun experience.
I should be able to just enter the outside diameter of my threadmill as a flat endmill like you describe and enter the pitch correct? Let me know if I misunderstood.
jeff.walters
you got it correct.
Jeff Walters
steveripplingerjr
Looks like it should work fine. Single point M36x2 threads. 2mm pitch
Machine will arrive next week then the true test will come!
https://screencast.autodesk.com/main/details/4b5df446-1ef0-414d-bc20-dcd85538dfed
I used a slot cutter.  Not perfect because it leaves a square thread, but at least I can see the thread pitch in simulation and get an idea of how far it is cutting...
Trigg3r
I've had some success thread cutting using a form tool by importing it from SW/HSMXpress via Excel to the Fusion Tool Library or directly importing the .hsmlib file.
Screencast linked below as for some reason embedding has stopped working again and gives an invalid html warning.
http://autode.sk/1wYGYOa
:slightly_smiling_face:
steveripplingerjr
Sorry for not following up on this.
I have used it a few times in Aluminum and TItanium making 4-40 threads using a Flat Endmill with the diameter of my threadmill as the tool. It has worked great so far after I figured out my tolerances needed for my threads.
