Announcements
Thread milling diameter
JJackrabbit
JJackrabbit
Hello
I'm trying to thread mill in steel. I need to make a bunch of M8 holes.
In my drawing the holes are 6.8mm. I also drilled the holes 6.8mm
But how does the threading option work?
I entered the pitch (1.25), if I enter the diameter of 6.8mm it won't cut away enough material.
Do I need to enter 8mm? or how is this being calculated.
"Pitch diameter offset" will make your day. In your case, 1.2mm.
David
JJackrabbit
Thanks, that seems to work
Tool plunges in and cuts thread from the bottom to the top
second pass also a straight plunge
third pass it moves off center before plunging in. One flute touched the part and got damaged...luckily the tool itself is still 'alive'.
How can I prevent the tool from making horizontal movements when plunging in?
Edit
Enabled lead to center, that should solve it.
JJackrabbit
Ok that seems to work
I have thread which looks good. Only it's too small, can't insert a m8 bolt.
Cutting diameter of the tool is setup right.
Or did I made a mistake by drawing the hole 6.8mm?
Should it be 8mm in the drawing? And then setup the thread cutting for m8.
Most thread mills have a slight corner radius on the cutting edge so it doesn't chip as easily but most CAM expect a sharp V. In all my years of thread milling I have all ways used wear comp and adjusted the tool at the machine to get it to check with a thread gage.
If your machine doesn't have tool comp the adjust the pitch offset till it gages correct. Also, check your lead in/out values to insure the tool doesn't make contact with the wall.
You modeled and set up it correctly.
JJackrabbit
thanks I will check the wear comp
Bolt almost fits but it needs another pass with the thread mill to make it a little bit bigger
On "Linking" tab, check "Lead to center" if you haven't done it already.
Most threading tools must be compensated about 0,06-0,08 mm.
David
Edit: I apparently didn't read all of the above. Double info.Smiley Embarassed
