Fusion Manufacture
The "Only Inner Corner" option is buggy
3 REPLIES 3
Sadovshikov_Vitalii
174 Views, 3 Replies
If for the "Sideways Compensation" option select "Right" then the "Feed Optimization" occurs on the outer corner instead of inner corner (when "Only Inner Corners" options is active). And conversely as expected the "Feed Optimization" takes place on the inner corner if "Left" is chosen. Why is this happening?
3 REPLIES 3
Because it's a ported unfinished / unrealized "feature" from HSMworks that was added to Fusion 360 without any intention of improving or fixing the bug
here is a 10+ year old thread mentioning the exact same issue
https://forums.autodesk.com/t5/hsm-support-forum/feed-optimization-control-cutter-compensation-backw...
Ha ha, how cool is that 🙂 I have tried both Powermill and Fusion 360, every time I touch them I wonder how clumsy and buggy they are in my opinion of course
Yep. Day one. I've raised this once again with the development team, I'd like to see this issue as a "thing of the past".
Seth Madore
