Fusion Manufacture
Techno CNC Post Tool Change issues
4 REPLIES 4
TaylorAus
150 Views, 4 Replies
Hello, we have a Techno CNC Router LC series and are trying to cam out guitar bodies, but for some reason every time that I post the code, it does not include tool changes. I have tried selecting the optional stops, tool changes, etc. I have even looked in the post configuration but I am unfamiliar with code. I am using the Post given in the Fusion 360 library of posts. Is there an alternative post I can use? I tried the RS-274D post, and it shows tool changes but in comment format and I would like to not have to change anything if possible. Attached is a sample code
4 REPLIES 4
seth.madore
in reply to: TaylorAus
Are you using the Techno post processor that you can find HERE?
There is a post property for "Use Toolchanger", is your set to Yes?
Seth Madore
TaylorAus
in reply to: seth.madore
Yes, and I have tried use the tool changer enabled and disabled.
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply.
Looking at the sample code from the post, it appears to be operating as expected 🤔
Seth Madore
TaylorAus
Hello, I solved this issue by going into my tool library and for each tool unselecting "Manual Tool Change" in the Tool Library>Edit Tool>Post Processor menu
