Fusion Manufacture
Teams like MO6 on the bottom line
2 REPLIES 2
Emre_Yucel
86 Views, 2 Replies
Greetings
When my machine is Fanuc io-mf post extraction, the MO6 team, which I shared the screenshot, should be in the bottom tab so that it can work without error, but I do this manually, what should I do to automatically assign the tools to the bottom line, thanks for your help in advance.
2 REPLIES 2
a.laasW8M6T
in reply to: Emre_Yucel
Hi
Find the code for (Line 640 of the latest standard Fanuc post)
case COMMAND_LOAD_TOOL:
    writeToolBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
    writeComment(tool.comment);
Change it to
    writeToolBlock("T" + toolFormat.format(tool.number));
    writeBlock(mFormat.format(6));
KrupalVala
Hi @Emre_Yucel ,
You can make the following changes in the function onCommand. You will get the expected output.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
