Fusion Manufacture
Tapping cylce produces wrong feedrate?
4 REPLIES 4
CuttingEdgeManufacturing
210 Views, 4 Replies
Hello, today I have a program that taps a 10-32 in the end of a bolt. Thread pitch for the tool in the tool library is .03125 (1/32 gives me pitch) my RPM is 1400, so taking rpm/ pitch of thread = 43.75. code posted out gives me Feedrate of 1.7224 which resulted in a bored out hole basically. Can't believe the form tap took it on but it did.
anyways I changed the code by hand and it works just fine, but not sure why its outputting the wrong feedrate. I went and double checked that similar form taps in f360 i have used already have a similar pitch(I was worried I was supposed to type in 32 instead of 1/32) but seems a 1/4-20 form tap i have in the library has a thread pitch of .05" so I'm fairly confident I have everything right and this is just a bug.
file attached to see if the problem is replicated on other systems.
4 REPLIES 4
I think this is a "units" issue, where the value is being regarded as Metric.
1 / 32 = .03125
.03125mm / 25.4 = .0012in
.0012in x 1,400 = 1.72ipm
Do you have either of these Preview Flags enabled?
Seth Madore
yes the user expressions is on. i dont even have the other one in my list, i see its a insider preview feature and i have the insider version.
If memory serves me correctly, try turning the Expressions one off, as I think that's the source of the issue.
Seth Madore
BrandonTBFBF
in reply to: seth.madore
I can confirm that this is the issue. I had the exact same thing happen to me. Turn that preview feature off and it should fix the problem.
