Fusion Manufacture
Takisawa TS-15 Fanuc 6T Machine and Post
2 REPLIES 2
shawnhuk1
166 Views, 2 Replies
Good evening folks.
I recently drug home a Takisawa TS-15 CNC lathe, and just this morning I managed to get it successfully communicating with the PC with DNC4U. Now I need to set up Fusion.
What are folks using as a machine in the library and the post processor for Fanuc 6t?
I did try to do a bit of searching, but my success rate for searching for answers (anywhere) is rarely ever fruitful.
I appreciate any responses and apologize if this topic has been answered many times already.
2 REPLIES 2
DanielMolloy
in reply to: shawnhuk1
Hi @shawnhuk1,
There are a couple of generic posts which may well work for this machine, i will include links below to these. One is the fanuc turning post and the other is a takisawa mill/turn post.
https://cam.autodesk.com/posts/download.php?name=fanuc%20turning&type=post
https://cam.autodesk.com/posts/download.php?name=takisawa%20mill-turn%20fanuc&type=post
In terms of a machine file, you wont need one, they can be added to include functionality such as machine sim, axis limits etc but should post fine without.
shawnhuk1
in reply to: DanielMolloy
I did find a Fanuc post, I will try this one too because the one I first used makes the lathe not accept canned cycles - particularly G71. But in the half-a-day I spent trying to figure that out I realised the G71-g73 canned cycle problem is significantly deeper than I first thought. I have found some solutions but I do not understand them. I need to investigate further but haven't yet had the time.
As far as this initial request, I suppose we can suggest it's resolved.
Thank you Daniel.
