Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Tabs creating seams
5 REPLIES 5
411 Views, 5 Replies
Tabs creating seams
Hi everyone,
I seem to be having a problem regarding the creation of tabs. At the moment, when I have tabs they create a strange seam that I can't seem to get out (other then post-producing of course).
Attached a picture of what happens (this is after sanding it already quite a bit) and the f3d file.
Thanks in advance if anyone is able to help!
Philip
Tags (4)
Labels (4)
5 REPLIES 5
And if it helps, here too is the NC file generated.  work with a CNC Step High-Z and I control it via KinetiC-NC
This showed up in recent weeks in another thread, problem with rectangular tabs.
Tool under load of cut deflects from stock, when it encounters tab, it stops progressing in X or Y direction and loses the load, while moving up in Z axis it leaves mark because it is no longer deflected due to cutting pressure.
On the other side of tab tool plunges into solid stock and vibrates because it works as a drill bit for duration of the cut between top and bottom of tab.
Select triangular tabs and problem will go away because tool will not stop at the top of tab, it will feed in XZ or YZ direction over tabs, up in Z axis to the middle of tab then down in Z over other half while feeding in X or Y axis at the same time.
Thank you very much. This will certainly help!
richardfferraro
I am currently cutting in mdf. This is a problem that others have helped solve.
I want rectangular tabs.
This works for me. No more ghosting and nice surface finish.
The big contributor is Sideways Compensation Right (conventional)
Tool
Choose tool (mine is 1/4")
Coolant Disabled
Spindle Speed 13000
Feed rate 1400
Geometry
Tabs 6.35 1.5875 selected
Heights
Bottom Height Offset -0.5
Passes
Multiple Finishing Passes off
Stepover .635
Finish Federate 1400
Roughing passes checked
Max stepover 6mm
Smoothing deviation .1mm
# stepovers 1
Multiple depths checked
Maximum Roughing Stepdown 5mm
Finishing stepdowns 0
Finishing stepdown 0.2
Approach Along wall
Rough Final checked
Order by islands checked
Linking
High Feedrate Mode Preserve rapid movement
Allow Rapid Retract checked
Safe distance 5mm
Keep tool down
Maximum stay down (200)
Lead in checked
Horizontal Lead-in .635
Lead in Sweep angle 0
Linear lead in .635
Lead out checked
Lead out same as lead in checked
in reply to: richardfferraro
Thanks. Will definitely try that as well!
