Fusion Manufacture
Syntec 22ma - 4 axis Simultaneous Machining Post Issues
1 REPLY 1
damienHJAZ4
372 Views, 1 Reply
Hi all,
First post here. We have been using the standard syntec post available for 3 axis machining for a while and has worked great on our Syil X7. Going to 4 axis work we are having problems.
Most recent is the post outputs G43.4 or G43.5 codes when doing the rotary toolpaths from the Machining Extension in Fusion360.
These are RTCP or TCP tool paths which are not supported by our Syntec 22MA controller without upgrading to what I believe is a 5 axis functionality.
Has anyone got a functional post for Syntec 22MA controller that allows for simultaneous 4 axis machining without outputing RTCP or TCP g codes? I am very sure it is possible but modifying posts is not my strong point.
I have attached the standard posts processors, and an updated one we received from another user to allow for positional work using 4 axis. Both output either G43.4 or G43.5.
Also attached a link to the part we are machining.
https://a360.co/3KAl0cY
Thanks in advance
P.S We have a modified post where cyclic:true and tcp:false was added to the createAaxis area, and it helped as in the code was outputed without error, but it tries to machine through the part instead of around it it looks like. Code shown below
function onOpen() {
if (getProperty("useRadius")) {
maximumCircularSweep = toRad(90); // avoid potential center calculation errors for CNC
gRotationModal.format(69); // Default to G69 Rotation Off
if (true) { // note: setup your machine here
var aAxis = createAxis({coordinate:0, table:false, axis:[1, 0, 0], range:[-360, 360], preference:0, cyclic:true, tcp:false});
machineConfiguration = new MachineConfiguration(aAxis);
1 REPLY 1
Hi @damienHJAZ4
Looking at the Syil post, starting with the onOpen function:
function onOpen() {
  if (false) { // note: setup your machine here
    var aAxis = createAxis({coordinate:0, table:false, axis:[1, 0, 0], range:[-360, 360], preference:1});
    var cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, 1], range:[-360, 360], preference:1});
    machineConfiguration = new MachineConfiguration(aAxis, cAxis);
    setMachineConfiguration(machineConfiguration);
    optimizeMachineAngles2(0); // TCP mode
Several problems for using this post with a fourth axis.
For the kinematic definition, if (false) .... SHOULD be changed to if (true) ...
Then at least one axis had to be defined and used.
As I suppose, you have a fourth axis bolted on the table, rotating the part, and not the tool, then the definition needs to be tweaked correctly.
(See the manual https://cam.autodesk.com/posts/posts/guides/Post%20Processor%20Training%20Guide.pdf )
The code for the kinematic will look like that, but you need to check the limits (-360, +360)
function onOpen() {
    var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-360, 360], preference:1, tcp:false});
    optimizeMachineAngles2(1); // no TCP mode
We define the A axis as a "table axis" without tcp support. The machine configuration use this a axis only, and we want to optimize for a non tcp machine.
TCP is a command optionnaly available on expensive controller for handling multi axis machine.
If we analyze the other post:
function onOpen() {
If true is ok,  enabling the axis defintion to be executed.
In the axis defintion tcp:false is missing and table:false is probably wrong. As it's not the head that is rotating.
And optimizeMachinesAngles2(0) is incorrect, there is not TCP support.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
