Syntax error post processor mac
rom_gerrun
rom_gerrun
Hi guys,
So I'm working on a mac and trying to figure out a Heidenhain post pro for a 5axis dmu50
Since I'm working on a mac I had to make a change to the PP to actually work.
Here is the procedure:
https://knowledge.autodesk.com/support/autodesk-hsm/troubleshooting/caas/sfdcarticles/sfdcarticles/E...
But I still have a syntax error and don't understand it
Iv'e attached the pp and also the error I have when post the code.
Thanks for the help
randyT9V9C
You are missing commas at the end of lines 60 and 85. Syntax is sometimes hard to see but it will get you everytime.
60   preferTilt: "-1", // -1: negative, 0:dont care, 1: positive TAG: Mac
85   preferTilt: {title:"Prefer tilt", description:"Specifies which tilt direction is preferred.", type:"enum", values:[{id:"-1", title:"Negative"}, {id:"0", title:"Either"}, {id:"1", title:"Positive"}]     }, // TAG: Mac
I've attached the corrected post processor.
rom_gerrun
Hey perfect it worked.
Tank you for the help
