Fusion Manufacture
SWARF goes laggy
3 REPLIES 3
camKV85U
114 Views, 3 Replies
SWARF goes laggy
Hi guys,
I hope someone could help me here.
I wanna run a swarf program but my machine goes laggy like it stops for a split second every time it switches C direction. I even switched off C axis brake (M26) and B axis brake (M71) but still not the result I want.
I am using generic Heidenhain post from Fusion library with the same kinematic Autodesk machine like my AXA ( CB table-head) in Fusion360 .
Thanks in advance!
3 REPLIES 3
a.laasW8M6T
in reply to: camKV85U
Can you share the file here, its very hard to diagnose problems without seeing what's going on directly.
From what I can see from that pic you are using swarf somewhat unconventionally which may be part of the problem
To share the file go to File>Export>save as .f3d
then attach in a reply here
camKV85U
in reply to: a.laasW8M6T
Thank for the reply. Attached the file.
I think the problem should be with the post settings...
a.laasW8M6T
Hi, yes there is a Post setting that should improve the behavior, i just wanted to make sure the toolpath looked "good" to which it does
this turns on CYCLE 32 which is the controls smoothing function
30 CYCL DEF 32.0 TOLERANCE
31 CYCL DEF 32.1 T+0.013
32 CYCL DEF 32.2 HSC-MODE:0 TA0.5
Check this out from Heidenhain for more information:
https://www.heidenhain.us/addl-materials/enews-pro/pdf/KLARTEXT_61_Cycle_32.pdf
