Fusion Manufacture
surfacing an undercut corner rad?
4 REPLIES 4
programming2C78B
96 Views, 4 Replies
Having a brain fart on this one, Friday issue. I can't get Ramp or spiral to work on it today. Can't share the file obviously.
I assumed this is where the old blend was used, but I need to add the .02 corner rads to these o-ring grooves. The keyway cutter has .015 rads on top and bottom
Please click "Accept Solution" if what I wrote solved your issue!
4 REPLIES 4
3D Contour and Steep and Shallow should both yield good solutions. Downside is that you don't get to use cutter comp..
Seth Madore
I cant get any of those to work!
Here's a very close example of what Im doing. It's actually a .01 rad, not .02 but that shouldn't matter in this case.
Well, I've been beating against a 3D Contour for a bit, trying to get it to machine ONLY those radii, and came up empty. So I resorted to something that I knew would work; Trim/Delete Passes:
Now, this IS an Extension item, so not everyone is going to choose to invest in that option. However, as a shop owner myself, it's my assessment that this one little portion of the Extension more than pays for/justifies the entrance fee. I've used Trim/Delete so many times in my shop, I've saved hundreds of hours of fiddling around with toolpath settings.
Seth Madore
back at it. Funny enough, I can get it THIS close without any Edits, but the instant I lower the top height to model top -.05 (to trim off the top passes) it doesn't generate AT ALL. What am I missing there?
