Announcements
Surface finishing
arne
Surface finishing
arne
Can anyone help me out here?
I'm getting not the surface finishes i want with 3d-machining.
I used 3d-morph for this particular Operation. Parallel doesnt work that great either.
I'm pretty sure this is a code issue not a mechanical one although it is a pretty old hurco bmc30 with ultimax 3 Controller.
Replies (7)
BjoernJohnsson
Hello Arne
Could you attach you model, then we can look into what's happening?
Björn Johnsson
Sr. Software Engineer for HSM CAM
Bjoern Johnsson
Principal Software Engineer
arne
Hi Björn,
here is the model file. And the NC-Code, I didn't know how to export the setup. But if u send me a pm with your mail I could invite you to this project.
Regards
Arne
BjoernJohnsson
Hello Arne
Is it possible for you to share the file with some of the operations where you didn't get the surface finish you expected?
I would like to see the generated toolpaths for those operations.
Björn Johnsson
Bjoern Johnsson
arne
I'm trying to figure out how to export the cam file
BjoernJohnsson
Hi Arne
There are some irregularities in the parallel toolpaths that might explain your surface finish, that stems from the triangulation of the surface. It can be improved by lowering the tolerance.
Or this is something you have already tried?
Björn Johnsson
Bjoern Johnsson
arne
I already tried to lower the tolerance but I bumped it back up again, since I thought having too many toolpath points (in the simulation) would cause the bad surface finish.
That is aswell the reason I put the smoothing that high.
arne
Might this even be a postprocessor problem?
Aren't arcs only allowed in XY Plane by default? Maybe allowing them in any plane might work...
