Fusion Manufacture
Stumped, trying to cut a curve out of a face frame I made
3 REPLIES 3
bobsprynDLZ22
141 Views, 3 Replies
Hey all,
Relatively new to the manufacture tab, using my new Onefinity. I'm trying to cut this profile curve into a face frame assembly I have glued together. I figured this was a 2D contour operation to cut the curves I've created on the bottom here.
Parameters are:
- I'd like to plunge outside ideally, but I haven't been able to get it to do this. This is my main issue.
- I'd like to cut on the inside of the curve (the side closer to the bottom). I have this working
- I'd like to do it in two operations, so I can switch to upcut for the second operation. I know how to do this part.
I'm guessing part of the plunge issue is related to the fact that it's not a single curve, but a set of three lines. I've not found any merge operation for sketch lines. Although I don't think this is the only issue, because I can't get it to plunge outside any of the lines.
3 REPLIES 3
seth.madore
in reply to: bobsprynDLZ22
Like this? (and a bonus selection method thrown in for free)
Seth Madore
bobsprynDLZ22
in reply to: seth.madore
Fantastic! Thank you!
I see that I didn't understand chain selection, but I do now. Thanks again!
