Fusion Manufacture
Stuck at Manufacture | Setup for plasma cutting
6 REPLIES 6
donGWDSC
268 Views, 6 Replies
My F360 file from Housemade.us, a 2x72 belt grinder design, has both a cut sheet sketch and an assembly view showing.  When I go to Manufacture, then Setup, F360 automatically selects the assembly drawing.  I cannot seem to be able to select my cut sheet sketch.  At this point, I am completely stuck and cannot move forward.  Any help will be much appreciated.
6 REPLIES 6
seth.madore
in reply to: donGWDSC
Fusion is a LOT happier when there is some sense of a solid model to work with. A quick extrude of the general size of stock would be sufficient
Seth Madore
donGWDSC
Seth, thanks so much for the quick reply.  New challenge:  If I select 1 part and extrude it, that works fine.  However, I am now unable to select any other part to extrude on the sketch.  If, however, I select all parts on the sketch, and extrude all, that works, except that F360 ignores all holes.
seth.madore
Would you be able to share the file (as it currently sits)?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
donGWDSC
in reply to: seth.madore
Seth,
Here you go.
Don
seth.madore
Give this a view:
Seth Madore
donGWDSC
Seth, gheez, I wonder how I will be able to repay you.  Thanks so much.  There is still weird behavior, but I'm on a path toward success.  All thanks to you.
Have a great weekend,
Don
