Strategy to use with angled corners.
Seb.Reamda
Seb.Reamda
Which strategy I should use to cut as much as I can from the highlighted area? Is there a way to use "trace" in a vertical direction? The part will be machined on 5-axis Haas UMC-750.
Tom.Hemans
Hi @Seb.Reamda,
I think Pencil might be able to help you with finishing those internal corners.
Hope this helps,
Tom
Tom Hemans
Technical Consultant
Seb.Reamda
Tom,
Thanks a lot for your reply.
I've just finished to generate the stencil toolpath and it works great!
Somehow yesterday I couldn't sort the 3D pencil toolpath.
Again thanks a lot!
dylan_smith
FYI you'll have a radius left in the corners on the shallow surface. Considering you have a UMC 750, you could tilt the head normal to the flat surfaces and use horizontal using a flat bottom tool.
Another viable solution.
Dylan Smith
Manufacturing Specialist
