- Mute
- Permalink
- Report
So my stock size comes out pretty rough due to poor bandsawing (e.g. a pretty slopey rectangular prism, and also more than an 1/8" undersized from the stock size I specified in the initial setup).
Let's say that the dims are roughly 1/16-1/8" undersized (smaller stock than expected).
Do I NEED to go fix this in the stock sizing for every part I do?
Say I left the setup stock size in 360 as what it was originally planned to be. When I then go to set my true z-zero on the actual machine at the true stock top, does it take this value into account and machine off less? Or will my part essentially end up 1/8-1/4" undersized if I did facing operations on both opposite sides.
Another way to say it is... Does the machine Z-origin that I set while actually machining override the 'stocktop' value and then the distance between 'model top' and 'stock top' float/calculate? I don't want to face both sides and have it be 1/4" smaller than it should be if this stock top value is rigid from the initial setup.
I'm failing to understand where my machine z-origin value fits in. In most of my operations I set the origin to be at the stock-top. I reckon I'd be able to change it to model top and then definitely play with my height/feed height clearances to make it work out.
