Fusion Manufacture
Stock outside of center Mill/Turn setup
4 REPLIES 4
endicott.12
187 Views, 4 Replies
Please see attached picture.
I am trying to do a mill turn setup but the stock isn't wanting to stay in the center.
4 REPLIES 4
Garrett_Wade
in reply to: endicott.12
Not sure whats going on without looking at the file but you could try drawing your stock in the design side then select it "from solid" in your setup.
engineguy
@endicott.12
Looks like you have selected one of the faces for the Z axis so that is where the stock is being centered, try going to your Origin and selecting the Z axis there instead of on the Model, worth a try 🙂
seth.madore
Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
endicott.12
in reply to: seth.madore
I'm sorry I have been inactive on this thread. I have been very busy.
I got it to work it just took a lot of trial and error with the setup.
I believe I had to set my stock up while I was in a turning setup then I had to change it to a Mill/turn
