Announcements
Stock model turns black as zoom in
mattdlr89
mattdlr89
My green stock models turns black as I zoom into it and is unusable.
Is this down to settings or hardware issue?
I've attached a few screenshots as I zoom in. It has always done this in my limited time of using Fusion 360 (a couple of weeks). Although today it seems to be going black at a lower zoom level than previously. A little frustrating when trying to inspect the stock model.
Hope someone can help.
Replies (7)
seth.madore
Change to these settings:
This is a long standing lighting issue. Using the settings above will greatly eliminate that
Seth Madore
mattdlr89
Hi Seth
Thanks for your quick response. I made the changes it didn't have any affect until I restarted Fusion.
All seems to be good now I can zoom in further than I'd ever need to without the model going black.
DarthBane55
@seth.madore
Seth, is that a fix for the %$#@$ easter egg?
seth.madore
No, we're stuck with that :winking_face:
Seth Madore
DarthBane55
:downcast_face_with_sweat:
martin.konarsky
I have chenged settings of Fusion, but it did not help. I am totaly disapointed and frustrated.
Does anybody have finaly solution?
Please have a look on videa attached.
thanks a lot
martin.konarsky
Hello all,
I have found solution when this happens.
It works for me, please try if it does work also for you.
When the model turns black I have to change the camera from orthographic to perspective and then back.
When the model is reloaded (regenerated) the problem disappears.
Of course, this is not a solution, but it helps. I believe, that Autodesk team will solve the problem, sooner or later.
best regards
