Stock from solid
Stock from solid
Message 1 of 12
Stock from solid
Hi all,
I am new to Fusion 360 and i have some trouble with stock definbition.
I am trying to use a solid as a stock but it doesn't work. Whatever the option i choose in the dialoig box, from "Fixed size box" to  "From solid", the generated toolpath is always the same.
The selected stock isn't taken in account.
Can you help me ? I can't find a tutorial for this.
Thanks.
Pascal.
Replies (11)
Message 2 of 12
Steinwerks
The 2D Adaptive and some other toolpaths assume the stock is square. If you can share the part here that would help.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 12
Could you explain me how i can send the file. I have tried as an igs but it is not accepted.
The model is a guitar neck with 3D contours.
Message 4 of 12
Steinwerks
File - Export and choose .F3D for the file type, then attach it to your Post Message here (under the text field).
Neal Stein
Find me on:
Message 5 of 12
Here is the file
I have tried different operations, contour, pocket ...
Message 6 of 12
Steinwerks
I'll take a look when I get home (about an hour).
Neal Stein
Find me on:
Message 7 of 12
Steinwerks
So in the file you shared, you didn't have the model selected in your Setup, or your stock model, and your geometry selections for surfacing were the body, and not the actual surfaces (this selection can be a little tricky at times). I've shared the one with some minimal fixes to keep the toolpaths constrained better.
Neal Stein
Find me on:
Message 8 of 12
Thank you for your help, i will check your file tonight at home.
What is the problem with selecting the entire body ?
I did this because i could'nt select individual surfaces with the sourrounding stock, how did you proceed ?
Anyway I thought it was Ok because the toolpath was generated with no warning.
About the model selection, i never really know what to do. i think i don't understand well what they mean by "model" (i'm French, so it's not always easy ...)
i had tried different options, selecting/unselecting to see the effect. I often hesitate between different strategies for a given machinig operation, maybe several options are possible, i'm not sure.
Message 9 of 12
Steinwerks
So instead of try to explain, I've made a screencast with your part with a few of the changes I'd make. Didn't edit the Contour toolpath, but many of the same principles apply.
http://autode.sk/1SG3Ubl
Neal Stein
Find me on:
Message 10 of 12
This screencast is a great tool. You did a very good job, better than I expected. Many thanks.
I now have to watch this video in detail to understand what you did.
Can the other users access this video ? i am sure it could be helpful for some of them.
Message 11 of 12
Steinwerks
It is unlisted, but anyone can use that link and view the screencast.
I'm still pretty new to making them, so that was actually the third attempt (although the second was interrupted by a message on Google Hangouts that showed up in the recording). I have found that order of operations is a big part of how smooth and understandable the recording is to follow, so not skipping steps or going back can be very helpful (and again, I'm still pretty new at it).
And thank you!
Neal Stein
Find me on:
Message 12 of 12
anderodriozolam
Community Visitor
Community Visitor
Thank you very very much! It was very helpful for me, I was just looking for that!
