Fusion Manufacture
ST-25Y feed rate issues in rotary poket
1 REPLY 1
jose.frias65NJ8
88 Views, 1 Reply
Hello, I am trying to use the 4th axis. on my machine to make a rotary pocket strategy but when I get the code my feed rate changes continuously as the strategy progresses. I need the feed rate to remain constant throughout the strategy. Does anyone know what I have to modify?
thanks.
1 REPLY 1
Does it actually change at the machine, or are you seeing a lot of feed rate changes in the code?
What your probably seeing is Inverse time feeds being output, which is normal for it to change constantly
https://www.haascnc.com/service/codes-settings.type=gcode.machine=mill.value=G93.html
