Fusion Manufacture
Spiral strategy added to 2D face processing.
2 REPLIES 2
monozukuri.daisuki.higucchan
154 Views, 2 Replies
2D face processing is currently only available for parallel paths with specified cutting angles.
We would like to have a strategy where the entry point can be selected from 4 corners (X+Y+, X-Y+, X-Y-, X+Y-), and from the starting corner, a spiral cut can be made toward the center by down-cutting or up-cutting.
2 REPLIES 2
@monozukuri.daisuki.higucchan
You can achieve  a similar result using a 2D or 3D adaptive toolpath.
If my post answers your question, please use Accept as Solution.
CNC Lee
Fusion 360 CAM Post Processor Expert
https://linktr.ee/cnclee
Thanks for the advice.
I had not thought of using a 3D toolpath strategy, but using 3D flat area machining gave me the toolpath I was hoping for.
Appreciate your help.
