Fusion Manufacture
Spindle not starting on Shopbot
2 REPLIES 2
aokere
112 Views, 2 Replies
I've been trying to use my files with a Shopbot CNC but the spindle does not start. Is there a setting that needs to be changed? And can someone explain why this happens?
2 REPLIES 2
Joshua.Aigen
in reply to: aokere
Hi @aokere,
On the Shopbots I have ran there is a dialog that appears as you load the program called Start Router/Spindle. At that point you press the start button and the Router/Spindle starts spinning. None of this has anything to do with Fusion it is a part of the Shopbot operating system on the machine. Having the post start the spindle may not be possible, but I would lack that knowledge as I'm not familiar with writing posts. I do know the Shopbot G-code is different than most other CAM g-code.
Joshua Aigen
Workshop Supervisor
CNC_Lee
in reply to: aokere
@aokere
Did selecting the Shopbot OpenSBP post from the Fusion Post Library solve this issue?
If my post answers your question, please use Accept as Solution.
CNC Lee
Fusion 360 CAM Post Processor Expert
https://linktr.ee/cnclee
