Fusion Manufacture
Speeds incorrect on setup sheet
5 REPLIES 5
huneilcampbell
136 Views, 5 Replies
The speeds on the setup sheet doesn't match the tool data. Is there a way to fix this?Untitled.jpg
5 REPLIES 5
Could you share the file that you're using in creating this setup sheet?
Seth Madore
Here's the file.
This certainly looks like a bug. If I create a Setup Sheet using the "old" process (.html), it returns this:
I've opened up CAM-43123 to investigate this
Seth Madore
Is there a way to change the speed on the setup sheet from in/min to ft/ min using the "new" process?
