speed on Z axis
speed on Z axis
speed on Z axis
Hi
I'm new in all this stuf, i have mave sonme project, i have made a cam and toolpath for contour. Everything is ok, made an .tap file for my cnc machine.
I use a 12mm plywood, 6mm tool, made each cutting for 3.05mm.
Opened a file on my mach3 on cnc machin and started milling process, but speed uz Z axis is very slow, it is getting till the starting place and going down un Z axis very slow, and after each depth it is comming out and again gooing down very very slow.
Where can i change a speed for Z axis?
porsbym
Is your Ramp and Plunge feed rates perhaps set too low?
All the strategies have individual controllable feed rates for the various kinds of movement.
ok where can i set it for Z axis? sorry for stupid question, i'm really new in it
porsbym
I have highlighted the Plunge Feedrate field in this screenshot for a 2D Contour example.
If you have ramping enabled, it will use the ramp feedrate instead.
thanks
and it will be for Z axis yes?
thanks
with that question everything is ok
speed on Z axes ir nice now
But now i have other problem with z axes.
Before start i set 0 point on material in mach3, but when i start my work, then spindel on z axes is going till top and push the stop button ther, so i understand, that somewhere in my CAM model fusion 360 i should write in max top of z axes or something like that?
ok after it goes till max top it is switching off, i press start again, but it is happening after every process, so thats mean, there is problem in some setup or what?
porsbym
Try changing "G28 Safe retracts" to "No" in the post dialog:
