Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Some models bugging during simulation
0 REPLIES 0
Message 1 of 1
programming2C78B
135 Views, 0 Replies
edit: It was because my model Opacity was down on this, and the stock had a hole the size of the inserts. Still have questions though. I find it weird how it resorted to only showing one face of the insert instead of fading everything?
there are these inserts in my part, as 3x separate components. They can't be bodies because it wont allow me to use 3 different rigid joints on them.
they are all selected in my Setup.
When I simulate, they not only move but are also only a single surface and not a solid! Here is the hole from the top
and from the underside!
Here is it with opacity down
 and back to full. How come there is no "machining" done to these inserts?
Please click "Accept Solution" if what I wrote solved your issue!
0 REPLIES 0
