Fusion Manufacture
Smoothing drops part of a path?
6 REPLIES 6
franklinLCDW
196 Views, 6 Replies
Engraving a path using Fusion 360 Trace. The design is made in Adobe Illustrator, exported as DXF.
Strangely, when I turn on Smoothing in the passes tab of the Trace options, one particular part of the curve drops out. With Smoothing off, it generates gcode that works correctly. With smoothing on, regardless of the smoothing amount, one particular bit of the curve, and it's always exactly the same bit, drops out (see pictures with smoothing off and smoothing on).
Is this a bug in Fusion 360, or something else
6 REPLIES 6
jhackney1972
in reply to: franklinLCDW
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
franklinLCDW
in reply to: jhackney1972
Fusion 360 file attached.
seth.madore
What post processor are you using?
Seth Madore
franklinLCDW
in reply to: seth.madore
The machine is a Makera Carvera; I'm using the postprocessor supplied by Makera.
seth.madore
Okay, I've downloaded the Carvera post processor and processed out your code. Unfortunately (or fortunately) the backplot toolpath does not show this skip:
You can also open this in NC Viewer (just drag the file onto the screen) and the results are the same
Seth Madore
franklinLCDW
That's extremely weird. The skip definitely exists in the machined piece, and vanishes with smoothing off. A bug in the machine firmware, perhaps?
