Fusion Manufacture
Small Stepdown in X Value at Transition Point Between Cylindrical and Dome Profile
5 REPLIES 5
jonathanBUCVS
163 Views, 5 Replies
Line 3 of code snippet below shows an X value change of 0.0009 at the transition point between the cylindrical profile and the dome profile. This is leaving a visible line in the part.
Tried a few different tolerances, post versions, etc, same results. Drew this test version in Fusion, so the arc and the line are tangent to each other.
G1 X1.8125 F0.003
Z0.8932
X1.8116
G3 X-0.0312 Z0. I-0.9214 K0.0287
G1 Z-0.08
5 REPLIES 5
Enabling spun profile seems to fix it. That said probably should not be needed on this simple example.
Mark Hughes
Owner, Hughes Tooling
Also found the tangential extension at the front seems to be causing the problem. If I set it to zero with spun profile disabled the short line move disappears. You can set a distance to cut below the inner radius on the Radii tab. Edit, it doesn't look like the tangential extension is actually doing anything in this situation.
See attached file.
Mark Hughes
Thanks @HughesTooling . Spun profile didnt even occur to us bc of the simple shape. I did have to set the tolerance to 0.0001 as you did. 0.0002 does not work. I wonder whats happening there. I have a hard time seeing where a tangential extension would have an affect on the positional moves when the tool is already in the cut. This sounds like a weird glitch in the kernel
Could be it just introduces a floating point error. One for @akash.kamoolkar  to take a look at maybe.
Mark Hughes
I'll make a ticket for this.
Akash Kamoolkar
Software Development Manager
