Small section is not populating with a clearing line
FacebookGroupMember
FacebookGroupMember
Hello - Can anyone assist with understanding why this small section is not populating with a clearing line? the angle is not closed off and is actually larger than some of the others. 1/16th end ball nose bit, with 3D adaptive clearing due to the multiple levels, however this section is flat and simply stops at the line shown.
Thank you in advance.
Replies (8)
Marco.Takx
Hi @FacebookGroupMember,
Can you please share your file?
Without seeing it, it is hard to help you with your problem.
It could be a setting like minimum cutting radius i.c.m. whit stock to leave. But it's hard to help without seeing you file.
Within Fusion 360, choose File > Export and save it on your desktop.
After that upload it to this topic so that one of us can take a look at it.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
FacebookGroupMember
Close up view...
mcarpenter28
Attached.
FacebookGroupMember
Attached in the Fusion support forum.
mcarpenter28
Odd that all corners and routes would machine, and this one corner would not.  That is what made me thing it is not related to min cutting radius, and I have stock to leave removed I believe.
Marco.Takx
Hi @mcarpenter28,
It seems like a BUG!!
But after I created a single component of it (So not multiple bodies) it works file for 2D Adaptive. but 3D Adaptive still doesn't mill that area.
So your workaround is to do it with 2D Adaptive.
@jeff.pek can you please bring this up to development.
2D Adaptive works OK
3D Adaptive doesn't reach that arrea
Marco Takx
mcarpenter28
Thanks - I did end up going with 2D Adaptive and just selecting all of the cavities.  Appreciate the help.
daniel_lyall
I would say a chuck of the problem is the model itself.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
