slot milling issue
slot milling issue
ok so every time i try to it make a slot no matter size or shape it gives me this any ideas on how to fix?
Error: Invalid contour(s).
Warning: No passes to link.
        Thank you
        joshua
LibertyMachine
It's really hard to tell without at least seeing a screenshot of what you are tyring to accomplish. The best way, honestly, is to share the file you are working on, or something quite similar to it so we can see what you are experiencing. Fusion makes it very easy to share your work: If the part is open on your screen, go to File, Click on Export, give it a name, choose where you want to save it on your computer, and then you can upload it here.
The other way, would be to go to the Data Panel on the left hand side, right click the file you want, click on Share Public Link, and then follow the prompts
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
