Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Slope in 3D Toolpaths (3D Contour)
6 REPLIES 6
phAWJX8
300 Views, 6 Replies
The slope Angle is set to 44-46 (See Picture)
I'm milling a chamfer, but why does it take a cut on the sharp egdes?
My old programs (2021) works fine with slope, but now it's always touching the sharp egdes?
Does someone have a fix?
6 REPLIES 6
GeorgeRoberts
in reply to: phAWJX8
Are you able to share a copy of the model? That will help us look into what might be happening here
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
phAWJX8
I cant share the exact file, because of customer service.
But it fails every time i do it, so i've attach a test file for you 🙂
GeorgeRoberts
Thanks! I've just took a look at this and it does seem strange.
It 'looks like' the slope setting is actually the contact angle of the tool, rather than the angle of the surface... You'll notice that it's cutting those sharp corners at 45deg from the surface(s)
I'm not sure if this is how it's meant to work, so i'll message a few people internally and see if I can get an explanation &/ raise a ticket to resolve this
George Roberts
phAWJX8
Thanks! 🙂
seth.madore
When you say "it worked in older files", what happens if you open up those older files, view the toolpath and then regenerate? Does the toolpath change?
I played with your sample file, and something (to me) seems off. If I swap to a .075" Ball Endmill, it produces what I would expect:
Seth Madore
phAWJX8
it working fine, but if i take a new toolpath but in the old file with the same old tool, it dosen't work
