simultaneous machining haas 4 axis
coryharris323
Message 1 of 14
coryharris323
hi gurus out there i am trying to get my pre ngc VF4 haas to simultaneously Machine a part which is basically just a drill head. The problem i am having is the tool path seem to not be anything like the path i have generated in fusion 360 instead of rotating the a axis and feeding along the X axis the program seems to  move across the Y axis while moving  in the Z axis . I have hopefully attached the right screenshots and fusion 360 export so you can see the paths im trying to create
cheers
Cory
Replies (13)
Message 2 of 14
daniel_lyall
Can post your model as well other it is a guess, To do this Go to File -> Export and save as a .F3D Archive File and attach it to your next post, if you can not post the file you can PM it to me or say in your next post you can not post the file and one of the Guys that do NDA work will help.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 14
coryharris323
i have pm you as i cant seem to be able to get the file to send
Message 4 of 14
coryharris323
is this the correct file i cant find f3d only f3z
Message 5 of 14
daniel_lyall
See this article for how to export a F3Dz file https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 14
coryharris323
try this
Message 7 of 14
coryharris323
ok i have sorted it out there where links i had to brake to get the file to export in fd3
Message 8 of 14
johnswetz1982
I am not positive but I think for the simultaneous paths your work origin has to be at the center of your rotation.
Message 9 of 14
coryharris323
by center of rotation do you mean on the center line? and the origin do you mean the machine origin not the sketch origin? as i have to have the machine origin at that position or my probe can not see its reader to set the xyz positions at the face of the job. i may have to set the machine postion with out the probe if that is the case.
cheers
cory
Message 10 of 14
daniel_lyall
You have to have the center of rotation set unless you have dynamic offsets or any of the other fancy setup positioning stuff.
This is why it was moving in the Y-axis and not just doing  A, Z and X-axis move.
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 14
johnswetz1982
Yes center of rotation (X axis ) would have to be the center of rotation for the platter. Origin meaning for the setup in the CAM environment. You can have the actual point anywhere along the X axis whether it is the top of the part or the face of the platter.
On the actual machine I believe you already have these coordinates in the controls some where for at least Y and Z You would only  probing for the X offset I believe.
Message 12 of 14
coryharris323
so if i set up like this with the origin in this position. This will fix my coding problem and it mill machine in X A Z
cheers
cory
Message 13 of 14
daniel_lyall
@coryharris323 Yes that will do it.
Daniel Lyall
The Big Boss
Mach3 User
Message 14 of 14
coryharris323
Thanks for the help i will look at setting up that way i will see if i can move the probe receiver so it can see the probe when the forth axis is on the machine.
