simulation with machine error
matthew_pitmanF2EMW
matthew_pitmanF2EMW
Ive recently programmed a part and want to check it against our machine for clearance. I thought kinematics are setup correct due having help previously. our machine is just an older version of the DMU50 listed on the fusion machine options however it looks like its having alot of Z overtravel issues but also when it moves from toolpath to toolpath it just plunges through the job but only in sim with machine. Any help would be helpful as im new to using the machine builder.
https://a360.co/3Ey98J0
boopathi.sivakumar
It seems like in the machine Z zero postion is wrongly defined in the machine sim file you have to lift the Z axis by 125 mm up approx.
I have attached the modified file for your ref
Boopathi Sivakumar
Senior Technology Consultant
