Simulation: Pause button doesn't pause
eerier_bleach0f
eerier_bleach0f
I've clicked on the pause button 30 times yet my simulation still plays:
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
programming2C78B
wasnt this posted before? And it has something to do with the pause button only being on the actual bars and not the space between on mac or something.
Does CTRL+Space work?
Please click "Accept Solution" if what I wrote solved your issue!
brekmiller
Ctrl+Space toggles Play/Pause on Windows.  The Command key on Mac is the equivalent of the Control key on Windows.  So on Mac it should be Command+Space to toggle Play/Pause.  Fusion will respond to Command+Space.  However, there is a problem.  By default, on Mac, Command+Space is intercepted by Mac Spotlight.
https://support.apple.com/en-gb/guide/mac-help/mchlp1008/mac
So Command+Space normally doesn't make it to Fusion.  You can go to System Settings and change the hotkey for Spotlight, then Command+Space will work in Fusion.  But don't do that.  We have made Fusion respond to Ctrl+Command+Space to toggle Pause/Play in order to avoid this problem.  The tooltip on Mac for the Play/Pause button says Ctrl+Command+Space.
Also, programming2C78B is right, you need to click on the bars, not the space between or around them.
Brek Miller
Software Engineer
