Fusion Manufacture
Simulation doesn't transition from one setup to the other
1 REPLY 1
lorenzo_cartaP27WE
78 Views, 1 Reply
Hi, I wanted to simulate the entirety of the machining process of a component, divided into different setups, but when the simulation of all the operations of a setup is finished and the simulation of the operations of the next setup starts, It's simulated as if that operation has been defined in the previous setup, obviously throwing errors. Is there a way to fix this?
1 REPLY 1
No, the Simulation does not transfer views over into subsequent Setups. You need to select and Simulate each Setup on their own, sorry. This is not a bug, just a limitation of the software.
Seth Madore
