SIMULATE BUG - 'SHOW SPINDLE DIRECTION' not functioning?
jon46XEC
Message 1 of 9
jon46XEC
Hey there Fusion Dev Team -
In Manufacturing - SIMULATE tool path - 'SHOW SPINDLE DIRECTION' toggle option does not function now.
Maybe after the last software update?
Replies (8)
Message 2 of 9
seth.madore
Hmm, it's working on my test, can you share your file here?
Seth Madore
Message 3 of 9
engineguy
@jon46XEC
Check your spindle speed, if you have it set higher than the spindle speed that is assigned to the tool in your tool library.
My test is showing the spindle direction if the spindle speed is below the spindle speed set for the tool in the tool library it`s working, if above the spindle direction doesn`t work.
However resetting the tool spindle speed gets it working again so does look like a "bug" from here 🙂
Message 4 of 9
jon46XEC
Hi Seth - Thanks for the quick response and your attention -
Here's a link to a test file that repeats the same display bug on my end.
https://a360.co/3CsYo9f
Message 5 of 9
jon46XEC
EG - Thanks for that suggestion.
Gave that a try but unfortunately no luck.
Message 6 of 9
engineguy
@jon46XEC
Sorry but I don`t have anything else right now, hopefully @seth.madore can get an answer from the developers.
I have tried a number of different files and all work OK, the only file that doesn`t work is the one you uploaded so no idea what is happening.
Message 7 of 9
seth.madore
Sorry for the delay in response, I've been on business travel for the past week. The issue comes from not having "Live Tool" selected in the tool library. Turn that back on and you will get the proper visual. In addition, having that turned off will not send the proper codes to the NC program and your spindle wouldn't turn on.
Seth Madore
Message 8 of 9
jon46XEC
Seth -
Well that works! - Strange though, I was understanding that toggle to be specific to lathe tooling.
I'm using a HAAS VF4SS Mill and a couple Laguna CNC routers.
Message 9 of 9
seth.madore
Ah, that's an oversight in the tooltip. Spindle Probes are also not intended to be spun....
Seth Madore
